1993 runs rough and when you put on pedal stalls
1993 VOLVO 940
DIWSE30
Engine Performance problem
1993 4 cyl Two Wheel Drive Automatic 240K miles
I changed fuel pump relay , got gas at rail, changed crank pos sensor, fires will not stay running sounds rough like its not running on all four. before it would not start at all untill i changed the crank pos sensor. help !!!!!!!!!!!!
Aug 17, 2008 at 3:26 PM
SERVICE WRITER
  • 9,123 POSTS
HAve you checked for spark at each cylinder?
Aug 17, 2008 at 3:37 PM
DIWSE30
have spark at all but I get it to start and it seems it not running on all 4 and stalls out unless I push the gas pedal in and runs rough
Aug 22, 2008 at 4:35 PM
SERVICE WRITER
  • 9,123 POSTS
IF spark is good, then check and make sure fuel pressure is in spec.
Check timing and check compression.
Aug 22, 2008 at 7:18 PM
