My 1992 volvo 940 turbo has gone thru 4 radiators in the past six months, granted that all the replacement radiators have been from the volvo recycle yard; they all looked to be in good condition with none of the tell-tell signs of any type of leakage. so my problem is, sometimes as soon as two weeks after the install of the recyled radiator, the upper radiator hose begins to leak at the clamp/hose connection to the radiator. first slowly with the cooling fan running extra long. then the old familiar smell of fresh coolant in the air comes- soon followed by steam/leak at the upper radiator to radiator hose connection. after i inspect it i see that the radiator connections from the radiator to the hoses are made in plastic and that the extended portion of the radiator has cracked off right at the hose/clamp area ( the part that is made of plastic. because of the lacation of the cracked broken radiator there is no other choice but to replace the entire radiator. can anyone tell me why this is happening and how i can remedy the situation?
Dec 28, 2008 at 5:24 AM
