Electrical problem
1992 Volvo 940 4 cyl Two Wheel Drive Automatic
This is about my '92 Volvo 940 car that the overdrive light will not go out. I think I may have solve my car's problem where the overdrive relay is causing the overdrive arrow to remain on even when I press the overdrive switch pushbutton on the shifter. Where is the OD Relay located? I think it is above the fuses on the central electrical unit behind the ashtray in the center console? Am I right? And also is this OD relay labelled or do I have to purchase a service manual to find the location? Please help? Also do you think it can be the overdrive switch on pushbutton shifter? I'm debating which is more likely the bad part?
Apr 18, 2008 at 2:29 AM
