1991 Volvo 940 RETRACTABLE ANTENNAE
1991 VOLVO 940
195,000 MILES • 4 CYL • 2WD • AUTOMATIC
MGOMEZ3
The retractable antennae broke (parking lot overhead)...I have found replacement antennae on WEB....question
1. Are these difficult to install?
2. Is there a manual that outlines replacement? If so how do I get a copy of the page(s) I need?
May 27, 2008 at 4:44 PM
Hi, it is fairly simple to replace the antenna mast, remove the base ring "nut" from the antenna. Then turn the radio, the mast will eject, remove the mast then trun the radio off while feeding the new mast in. Reinstall the nut and you are all set.
May 30, 2008 at 11:32 AM
