Volvo 850 2.0 /1994/Hydraulic Clutch
1994 VOLVO 850
RACH660
:?: We've had to replace part of the hydraulic clutch pipe as it was rather aged. We then went to drain the fluid out in order to get the thing on the road. But sadly we seem to be having some problems in doing so. :? As the clutch has no presure in the pedal it appers the only way to pump the fluid out is to blow through the fluid refil chamber and then its only spitting. :roll: Can you help at all we'r on a dead line for the www.SCALLYRALLY.co.uk check it out. :wink:
Aug 21, 2007 at 11:23 PM
2CARPRO JACK
  • 11,533 POSTS
The filler is attached to a master cylinder, I wouldnt advise you blow through it, or you could damage the seals.Your hydraulic clutch is similar to a brake system in that it will need to be bled to remove the air before you will have a clutch pedal again. There should be a bleeder valve on the slave cylinder to let the air out.
Aug 22, 2007 at 7:44 AM
