I have a 95 850 Turbo - the check engine lights came on and the codes indicated that the O2 sensors and the knock sensor needed replacement -- I have not replaced either -- my son is driving home and a loud noise starts from engine -- the car will start but has this loud noise -- i took the coil wire off and turn over the engine and all seems fine -- no noise -- he said that the car was starting slower than before -- i'm wondering whether my time belt has slipped or that the knock sensor going out is causing the loud noise -- took the middle 2 plugs out and both seem fine -- oil is full -- no water in oil -- other ? when a turbo goes out, does it make any noises?
Thanks for your help
Mar 3, 2009 at 3:07 PM
