Rear of car shakes when i brake at slow speeds
1994 VOLVO 850
MADVEY333
94 850 volvo wagon...When i brake at slow speeds, coming to a stop. As I stop, the rear end of the car will shake/vibrate for 2-3 seconds. This duration happens when the car has already been stopped sometimes. Seems to be more of an transmission problem rather than a braking issue. Any help would be appreciated. Thanks
Jul 28, 2008 at 5:48 PM
This does sound like a brake issue rather than a transmission issue. However, the easiest way to tell is before you start braking to come to a stop, put the transmission in Neutral and then come to a stop.
If it still, does it then it is most likely a brake issue.
If you feel this in the rear of the vehicle then it is the rear brakes.
Here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Below you will find the process from the manual that will give the remaining detail needed.
Please run through this and let us know what happens. Thanks
Nov 12, 2021 at 3:11 PM
