1994 Volvo 850 oil pressure
1994 VOLVO 850
187,541 MILES • 6 CYL • 2WD • AUTOMATIC
MEGABITE787
The car throws oil out the fill cap and the dip stick.
Mar 13, 2009 at 12:53 PM
RACEFAN966
  • 5,029 POSTS
Ok have you done a compression test on the engine?
Mar 13, 2009 at 9:13 PM
MEGABITE787
Whats the normal compression for these engines, 5 cylinder non turbo. Could it be anything in the oil breather system.
Mar 14, 2009 at 3:36 PM
RACEFAN966
  • 5,029 POSTS
You could check the PCV valve and the breather system make sure it is clear and free flowing. As for compression do a compression test and tell me what you find and I will let you know if it is in spec at that time.
Mar 14, 2009 at 7:38 PM
