1990 Volvo 760 Car leaking coolant profusely
1990 VOLVO 760
ANDRE10
Engine Cooling problem
1990 Volvo 760 4 cyl Two Wheel Drive Automatic 260k+ miles
What are some of the problems associated w/ coolant leaking? what should I look out for?
Mar 18, 2010 at 11:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
many components can cause coolant leak, the most common being cracked radiator or radiator hose, failing water pump or a failed cylinder head gasket. try to determine where the leak is starting at by drying up all the wet spots then watching new wet spot to form.
Oct 15, 2010 at 4:42 PM
