1987 Volvo 760 headliner change...
1987 VOLVO 760
DDRAVE
1987 Volvo 760 160000 miles
We are in the middle of replaciing the headliner in our volvo and cannot figure out how to remove the passenger visor with a lighted vanity mirror. Can you help???
Oct 9, 2010 at 4:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Locate the visor's mounting bracket. Many brackets have a cover hiding the screws that hold the sun visor in place.
Use a flat head screwdriver to carefully pry the top corners of the cover up. Do this gently because the plastic is thin and can easily crack and break. If your vehicle doesn't have this cover, skip this step.
Pop the cover off and you'll see some Phillips head screws. Hold the sun visor up with your arm so both hands are free. Use the Phillips screwdriver to remove all the screws. You may need to apply a little force to budge them. Put the screws in a safe place so they don't get lost.
Remove the sun visor from the headliner of the vehicle. It may just fall off once all the screws have been removed. Or you may have to give it a gentle tug.
Oct 15, 2010 at 4:47 PM
DDRAVE
thanks so much for your help... we just cut the headliner where the wire was and fed it through the hole... you really cant tell!
Oct 15, 2010 at 9:43 PM
