The idiot llights (test mode) should be on when the ignition is on and no AC (yes, AC not DC) is detected from the alternator. This voltage is contected by a single wire using a push-on spade connector to the back of the alternator. Try disconnecting this and re-connecting in case of simply a corroded connection. It happened to me. Note: if you have a tac, it uses the AC to calculate the RPM. If this AC connection fails, the tac drops to "0".
Jul 2, 2008 at 2:47 AM
