1988 Volvo 740 OIL LEAK
1988 VOLVO 740
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
SKYBYRD58
I had my engine gaskets changed about a year ago because of engine oil leaks and now they have started up again with a vengeance. The leak seems to come from around the dipstick area.
One thing which is strange is that my engine oil dipstick continually is pushed up out of the oil dipstick tube. I checked it and there is a lot of pressure coming from the dipstick oil tube. I have to manually tie down the dipstick to keep it in place. The oil may be spouting from the dipstick tube but when idling I don't see it.
Does that give any indication of why it's leaking so badly?
Thanks.
May 21, 2010 at 12:15 PM
2CARPRO JACK
  • 11,533 POSTS
check the PCV valve to be sure it isnt stuck, also be sure any other breather lines are attached adnnot pinched/kinked off.Something isnt allowing the crankcase to breathe, which will cause a ton of oil leaks
May 24, 2010 at 8:13 AM
