information on volvo 240dl estate
1924 VOLVO 240
MRS J MANLEY
having to top up the radiator going on a run gauge running high into red chacking under bonnet i have noticed steam coming out of the pipes leading into the heater matrix how can i take out the old heater matrix to replace with a new one and would that solve the problem of losing water i have no visible leaks anywhere that i can see
Aug 16, 2007 at 7:00 AM
SERVICE WRITER
  • 9,123 POSTS
Don't replace anything without just cause. It may be a fine leak that you don't see, or it may be an internal leak. Pressure testing is the best way to go after this.
The cooalnt should be a 50/50 mix. Too weak or too strong can cause problems.
Aug 16, 2007 at 8:25 AM
