1992 Volvo 240 Lean fuel problem
1992 VOLVO 240
JGS1951
  • 5 POSTS
1992 Volvo 240 4 cyl Two Wheel Drive Automatic
I have engine codes 231 & 221 which indicate a lean fuel condition. Can you give me any causes of a lean fuel condition? Thank You
May 17, 2008 at 7:56 PM
BLACKOP555
  • 10,386 POSTS
most likely there is a exhaust leak before the sensor, or there is a vaccum leak after the MAF sensor or a failing maf sensor.
a o2 sensor that is bad could cause this also, but are a bit more expensive to check then the ones i listed above.
Jul 17, 2008 at 6:24 PM
