1990 Volvo 240 Trouble Starting
1990 VOLVO 240
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRETGOLFER
When it is hot or humid out it takes 3 or 4 attempts before the car will start. I have changed plugs, wires, dist cap, rotor button, fuel pressure reg., and fuel pump. What else could it be?
Aug 6, 2010 at 12:00 AM
Check the fuel pressure if its within specs though its a new fuel pump if okay, test the coolant temperature sensor- and check injectors if its leaking could also be the ignition switch
Aug 6, 2010 at 2:41 AM
