1989 Volvo 240 How to replace all drive belts
1989 VOLVO 240
Engine Mechanical problem
1989 Volvo 240 4 cyl Two Wheel Drive Manual
I have no problem loosening the alternator and power steering belts, but the AC compressor is driven directly from the crankshaft pulley and has no belt adjustment bracket. Do I need to remove the compressor and mounting bracket from the engine, or just the clutch pulley from the compressor?
Jul 21, 2008 at 5:32 AM
BMRFIXIT
  • 19,053 POSTS
Haven’t seen one in years
but if I recall correct u need to loosen the bolts at the crankshaft pulley
that will allow you to remove the belt
good luck
Jul 21, 2008 at 6:14 AM
