1987 Volvo 240 Brake Light Switch
1987 VOLVO 240
24,800 MILES • 4 CYL • 2WD • AUTOMATIC
DEADBOB
I cannot figure out how to get to the brake light switch. I removed the lower panel (plastic screws) to expose the cruise control switch. Do I need to remove the instrument cluster? My Haynes Repair Manual shows that it resides just above the steering column. It says to "Remove the panel under the dashboard".
updated 11/28/09
To reply to your remark, the brake switch and the cruise control switch are separate. They shouldn't be, but they are. To get to the brake switch, we removed the cruise control plate, but that still didn't allow us access. So, we took out the instrument cluster. One person had to guide from the top while the other person got to the switch from underneath. We tested the switch, and it's fine. Now, we have real problems. Since the diagnostic module (I forget what they call it, but it's supposed to give indications of bulb failure, etc.) did not act properly when we tested it, we're proceeding to replace that in an attempt to find the failure. All other lights work fine. The electrical diagrams for the vehicle don't show anything besides the fuse box as being in the circuit. Now, the fun begins. Also, I had purchased a replacement switch, but you're really stuck using the Volvo part, because there's no way that you can make any adjustments on the switch against the brake pedal. The Volvo switch has only one nut on it, and you fit it into the plate and lock it down. The other switches have 2 nuts; one for each side so that you can make the necessary adjustment to 5/32 " from the pedal.
Wish me luck hunting for the short.
Dec 22, 2009 at 5:21 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much apreciated. The Stoplight Switch is located on brake pedal bracket. accessable by removing the lower panel ! Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_2carxmas2_18.jpg
Dec 23, 2009 at 5:45 AM
DAVE H
  • 13,384 POSTS
Hey, Sorry for the confusion .. my fault entirely ,, the stoplight switch and cruise control switch are intergrated .. they are the same switch .. the stoplight switch disables the cruise control !! Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_2carxmas2_22.jpg
Dec 24, 2009 at 4:04 AM
