1986 Volvo 240 engine won't contiue to run
1986 VOLVO 240
KEITH STEENSEN
Engine Performance problem
1986 Volvo 240 4 cyl Two Wheel Drive 150000 miles
engine will start and idle briefly (3 or4 seconds) and then die. Ihave checked the in tank fuel pump and replaced the fuel filter, fuel pump, and the pressure regulator. It seems to have good spark also. the car hit something in the right front, but there is not much damage, just cosmetic.
Mar 3, 2010 at 5:45 PM
2CARPRO JACK
  • 11,533 POSTS
What is it losing when it dies? have you watched the fuel pressure with a manual gauge to see what it is doing?
Mar 5, 2010 at 5:06 PM
KEITH STEENSEN
I checked power to the fuel pump when it was running and dyeing and I held the key in the start position when it died and it would not continue to run. I don't have the fittings to hook up a pressure gauge in line to test pressure while car is running.
Mar 5, 2010 at 5:57 PM
2CARPRO JACK
  • 11,533 POSTS
If it is holding spark, you are going to have to verify fuel pressure somehow, just checking for power to the pump wont do it, it can have power and still not work
Mar 6, 2010 at 8:16 AM
KEITH STEENSEN
have checked fuel pressure at log and it holds 35 or 40 lbs. while running and 40 to 45 lbs. whil cranking. I can't find specs in my manual. has power at coil, has spark, actualy runs good for 3or 4 seconds, then dies. if you pump the throttle very rapidly you can make it rev up a little and run a little longer.
Mar 7, 2010 at 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
Next step is to use a "noid" light and see if it is losing injector pulse. This could be a Mass Airflow Meter, or possibly a cam or crank sensor issue if it is holding fuel pressure.Be sure there are no vacuum leaks in thesystem between the MAF (airbox) and the engine
Mar 13, 2010 at 7:39 AM
