Voltage regulator location
1984 DODGE ROYAL
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
KOHLLINK
  • 80 POSTS
Cannot find the voltage regulator under the hood.
Aug 29, 2017 at 5:45 PM
CARADIODOC
  • 34,306 POSTS
Depends on which engine and which alternator you have. It could be built into the alternator or it could be their common two-wire regulator that is bolted to the firewall. The one on the firewall has a three-terminal triangular plug, but with only two wires in it. Throughout the 1970's those were dark blue and dark green wires. Not sure if they kept those colors on an 1984 model.
Aug 29, 2017 at 6:19 PM
STEVE W.
  • 15,113 POSTS
It should look like this and be bolted to the firewall just toward the passenger side of the truck.
Aug 29, 2017 at 6:47 PM
KOHLLINK
  • 80 POSTS
Thank you.
Aug 30, 2017 at 3:14 AM
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Aug 30, 2017 at 5:02 PM
