I have replaced the compressor; the car is throwing no codes for the "F" codes so no problem there. I also checked all of the sensors and cleaned them, they work. Had it working for 30 minutes before it stopped. I checked refrigerant level and I checked for voltage from the plug that connects to the compressor for the clutch. It read 14 volts. Clutch works because I hooked it up to my battery and heard it click, but when I try to connect the plugs together, I get a voltage reading of near zero. I spent almost a month trying to fix this, need help please.
Jul 8, 2023 at 4:46 PM
