2004 Volkswagen TDI Turbocharger
2004 VOLKSWAGEN JETTA TDI
HENNIE LE ROUX
Engine Performance problem
2004 Volkswagen TDI 4 cyl Front Wheel Drive Manual 100k miles
Hi there. I drive a vw jetta 1,9 tdi. after the turbo was replaced by myself due to turbo failure the new turbo wont kick in at all. Ive checked all pipes and connections but can't find any obvious reason. can you please suggest what to look for.
Oct 25, 2010 at 6:16 AM
DR LOOT
  • 2,311 POSTS
Did you replace the waste gate also?
Oct 31, 2010 at 11:21 AM
VWSCOTT
  • 66 POSTS
MAF sensor can cause turbo to be inop.i use a bad 2.0 MAF sensor on a tdi to diagnose. will allow turbo to work but will cause a check engine light too... only use for diag purposes.
Jul 7, 2012 at 12:14 AM
