2002 Volkswagen TDI turbo fault
2002 VOLKSWAGEN JETTA TDI
SHAUNGUILD
Engine Performance problem
2002 Volkswagen TDI 6 cyl Front Wheel Drive Manual 92.567 miles
my turbo kind of turns off while driving and only resets itself on the ignition key?.please help
Mar 12, 2010 at 10:04 AM
CWTDI
  • 4 POSTS
Check to make sure that the engine control mondule connectors are pushed on tight and the large round connector's clamping bracket is turned tightly on.
Mar 28, 2010 at 9:56 AM
CWTDI
  • 4 POSTS
I just found quite a bit of oil in the bottom of the turbo intercooler. I have unscrewed the nut holding the tube up and unclipped the connector to the bottom of the intercooler connector. Then I cleaned out the oil in the bottom of this plastic intercooler assy. I think the oil will restrict the air flow enough to shut off the turbo boost. I have not had any problems since.
Apr 20, 2010 at 4:59 PM
