1990 Volkswagen Rabbit
1990 VOLKSWAGEN RABBIT
132,000 MILES • 4 CYL • 4WD • MANUAL
TLGFIVE
my 1990 rabbit has constant injector power with the key on. testing with a noid light and there is no spark either
Feb 12, 2009 at 7:28 PM
DR LOOT
  • 2,311 POSTS
your rabbit onboard computer sends spark to the ignition if you have no spark, and you've checked all your connections, including the connection on the distributor, the only other thing it could be is a bad computer, check to make sure you have power to your distributor with the key on, and if you do not, you have a bad computer, it can be repaired for about $100, or you can just find one of the junkyard
Mar 29, 2009 at 12:54 PM
