1984 Volkswagen Rabbit fuel system problem
1984 VOLKSWAGEN RABBIT
115,000 MILES • 4 CYL • FWD • MANUAL
MOLTENGIJOE
my fuel system cut out on me the other day, i replaced the fuel pump with a used pump from a 81 rabbit it works, then my fuel filter, then discovered the relay was bad so i fixed it, now it still isnt pumping out fuel to the engine any idea on what it may be?
Feb 25, 2008 at 1:08 PM
Check the fuel pressure and also for an injection pulses from the injector/s.
Do you have spark? If so spray some carb. cleaner into the throttle body -did it start and die-if so continue to troubleshoot the fuel system.
Feb 25, 2008 at 1:14 PM
MOLTENGIJOE
ive got a spark the injectors are clean its just im not getting fuel even before the fuel filter
it cranks and turns spark and all just no fuel
Feb 25, 2008 at 1:24 PM
Do you hear the fuel pump come On when you turn the key to run-if so check the fuel pressure-if not check for power at the fuel pump connector.
Feb 25, 2008 at 1:46 PM
MOLTENGIJOE
yup i hear it start pumping when i turn the key, how should i check the fuel pressure?
Feb 25, 2008 at 1:50 PM
Please! do so and comeback with your readings.
Feb 25, 2008 at 5:22 PM
COGNITO
  • 28 POSTS
Their is a fine mesh cup in the gas tank which is a prefilter.Remove the fuel tank sender and you will see it at the bottom of the tank.Their is a handle on the filter[like a pail]that you can reach with a coat hanger,pull and discard the filter.
Mar 13, 2008 at 11:55 PM
