2004 Volkswagen Polo
2004 VOLKSWAGEN POLO
67,000 MILES • 4 CYL • 4WD • AUTOMATIC
ABIGAILP
I recently had a 60,000 km service, which indicated a number of replacements required. The major one was the timing belt and all associated pulleys/cams. and water pump.
The items were replaced and the next day the car would not start, I was informed by an independant mechanic that it was not the battery. It was towed back to the garage and the investigation showed that 2 of the ignition coils need to be replaced. Are these 2 items (ignition coils and timing belt) connected? Or was it just coincedence?
And do I need to have all 4 ignition coils replaced as advised?
Thank you.
Oct 27, 2009 at 2:23 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I think that it is a case of just plain bad timing, the coils and the timing belt are totally independent and there will be no bearing on either when the work is carried out, i would not worry about changing the other coils, there is no reason to, but if you want to that would not be a problem.
Mark (mhpautos)
Oct 27, 2009 at 4:37 AM
ABIGAILP
Thanks for your advice, I have know been told the throttle body has gone and the 4 spark plugs as a result of trying to get the engine to start.
Expensive!
Oct 27, 2009 at 10:52 PM
MHPAUTOS
  • 31,937 POSTS
I would question the problem with the throttle body, what are they saying is the problem there?
Mark (mhpautos)
Oct 27, 2009 at 11:08 PM
