I have a 2007 VW Passat 2.0T with an alternator charging problem. It charges intermittently or not at all. It does not charge the battery fully. The alternator has been replace, however it did not fix the problem. Wiring harness has been check and was found to have good continuity. The mechanic suspects that either the Vehicle System Control Module or the Engine Control Module is faulty. I understand electronic very well; however without schematics for the two modules, I am not able to determine how the two Control units function with the alternator to properly charge the battery and supply vehicle operating power. From a high level wiring diagram we can see there are two wires that appear to be routed to the alternator field windings. Can you provide any suggestion of what could be the problem and/or an explanation of how the two unit work to maintain proper charging. B.T.W. the generator warning lamp has never turned on (even though the batter voltage has drop below 10 volts).
Thanks,
Mitch
Thanks,
Mitch
Oct 25, 2009 at 2:10 AM
