2006 Volkswagen Passat My car shimmies when I drive under 5
2006 VOLKSWAGEN PASSAT
42,000 MILES • 4 CYL • FWD • AUTOMATIC
CHELLIEF
As I am excelerating my car shimmies and my steering wheel shakes and shimmies actually my whole front seat area does too. Can you tell me what might be the problem? And how can I fix it?
Jan 16, 2009 at 1:36 AM
SERVICE WRITER
  • 9,123 POSTS
Get a very close look at the wheels and tires. You may have to jack it up to get a good look. Sounds like possibly loose lug nuts, badly bent rim or most likely a shifted belt in a tire. The tire will have a pronouced bulge in the tread.
While the front wheels are up, check the steering/suspension components by placing your hands at opposite sides of each wheel and using a push-pull motion. Use 12 and 6 o'clock, 3and 9 o'clock positions.
Jan 16, 2009 at 6:03 AM
JSULLI33
You may want to have your cylinder spring checked out...if the engine shakes the car you may be only firing on 3 of your 4 cylinders...
I recently had one go bad on my v6, and I experienced the same thing...the whole car would wobble...
Apr 16, 2009 at 1:41 PM
