2004 Volkswagen Passat PO421 Bank 1
2004 VOLKSWAGEN PASSAT
134,000 MILES • 6 CYL • AWD • AUTOMATIC
RSM
  • 14 POSTS
Check engine light has been coming on and turning itself off for the last few months. It is steady, not blinking. I was told if it blinks that the converter has failed. I have notice no deterioration in performance or fuel economy. Is there a way for a relative novice to check the 02 sensors, for a fouled plug, the converter to diagnose this problem? Thanks,
RSM
Nov 23, 2008 at 4:52 PM
A code P0421 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
A sparkplug is fouled up
You might want to have the exhaust gases checked before and after the catalytic converter to rule out a defective converter-inspect spark plugs-measure the oxygen sensors switching activity
Possible Solutions Measure the voltage at the oxygen sensor on Bank 1 (the rear sensor, or the sensor after the converter). In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into
Nov 23, 2008 at 6:23 PM
RSM
  • 14 POSTS
Thanks for your prompt reply. Could this be caused by the need for a software upgrade? Engine specs are V6 30 Valve 2.8 Liter.
Nov 23, 2008 at 6:44 PM
Have the oxygen sensor checked and tested its sensing that the ctatalytic converter is malfunctioning-
Nov 23, 2008 at 6:51 PM
