2004 Volkswagen Passat Oil light and stop indicator light
2004 VOLKSWAGEN PASSAT
119,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHNSR
I just had my 04 passat serviced with an oil change, new oil filter, gas filter, new valve cover gasket (was leaking into plugs) and new plugs. The oil light comes on sometimes at 2500 rpm's and then goes off. The pressure reads 25 pounds at 2500 and should be 29 pounds. The mechanic thinks that this could be caused by the screen on the oil pump from a build up of tarnish. My question is, could this happen because we are using a thicker oil now because I would run out at the 3000 mile mark before the next oil change, or could it be a sensor?
Sep 12, 2010 at 10:30 AM
Hi johnsr, Welcome to 2carpros and TY for the donation this is what keeps the site going.
The best thing to figure this out is to actually check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump or engine bearings
Sep 12, 2010 at 5:59 PM
