2003 Volkswagen Passat
2003 VOLKSWAGEN PASSAT
39,906 MILES • 6 CYL • FWD • AUTOMATIC
RONALD NINO
I have had each tire balanced and an alignment to rid the car of a vibration. The vibration still persists. Do you have any other suggestions for me?
Thanks!!!!
Jan 7, 2009 at 8:29 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation.
If the vibration is in the body only and not felt in the steering it will be a rear wheel problem, if the vibration is felt in the steering it will be in the front drive line, if only felt when braking it will be a faulty brake rotor, also to a lesser degree loose drive shafts, faulty wheel bearings, worn steering & suspension components can also cause a vibration, but often it is a wheel problem, maybe get them checked by a second work shop just in case the first shop had a problem with there equipment.
Mark (mhpautos)
Jan 7, 2009 at 10:23 PM
