2002 Volkswagen Passat timing chain / cabin filter
2002 VOLKSWAGEN PASSAT
74,000 MILES • 6 CYL • AWD • AUTOMATIC
DREWDOKKEN
Looking at the front of my motor I have a metal cover over my timing belt? But is it a belt or chain? if a its a belt when should it be changed?
Also does my vw have a cabin air filter that should be changed?
Dec 17, 2007 at 9:51 PM
HIGHLANDER1
  • 6 POSTS
is your car petrol or diesel?
the 2.5 tdi unit has a timing belt and you need special tools to lock the engine when changing the belt
cabin filter is located under the panel where the wipers are you have to lift of the trim that covers the battery and the filter is there
normally replace them every 10,000 miles
Feb 6, 2008 at 4:56 PM
