2002 Volkswagen Passat Timing Belt
2002 VOLKSWAGEN PASSAT
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUNCHL
What should be the average lifetime of a timing belt for this vehicle, and what should be the approximate cost for replacing the timing belt?
Jun 29, 2008 at 12:21 PM
2CARPRO JACK
  • 11,533 POSTS
Should be replaced before 100k miles. You are looking at around 4.5 hrs of labor at what ever the shop charges, the belt is around $65 If teh water pump is run by the timing belt then it needs to be repalced at the same time which is another .2 labor plus the pump which is around $80
Jun 30, 2008 at 7:48 AM
