Ok, bear with me here. Quite some time ago I was driving down the road and brake failure lights came on on my dash. I pulled over and tested the brakes on the side of the road. Noticed no degradation of performance of the brakes so I drove the car home. The warning lights intermittently would come on and off seemingly randomly. I realized it had been quite a while since I replaced the pads so, not having the time to do it myself, I took it to Mineke. They kept the car a day and said I needed rotors and pads. I Ok'd this and they replaced them. The brake warning lights did not go off. I mentioned this to Mineke and they said I may need to take the car to Volkswagen to get them to turn the light off. I have not done this yet because it appears to be just a nuisance. Now, however, the brakes are scrubbing. I have pulled the brakes apart and found that nothing obvious is wrong. Pads are still good, rotors are smooth and unworn. Caliper piston is not sticking and it's getting brake fluid from the brake lines. The car stops just fine but there is a constant scrubbing or grinding as if the pads are not releasing all the way after I apply them. I haven't driven the car much since the brake problems began but need to get it running now.
Aug 23, 2009 at 11:26 AM
