2001 Volkswagen Passat leaking oil
2001 VOLKSWAGEN PASSAT
82,000 MILES • 6 CYL • AWD • AUTOMATIC
BRITTANYORTON
We live in Alaska and we bought this car about a month ago. I noticed the other day that there was some oil in the garage. Today that spill turned into a massive "lake" of oil and the car's oil light came on and said there was no oil in the car. I know I have a big problem, but I would like to know what could be causing this so I can go into the machanics a little prepared.
Jan 16, 2008 at 4:38 AM
2CARPRO JACK
  • 11,533 POSTS
Usually if it leaks that much overnight the problem is low on the engine like a drain plug or possible pan gasket. Some VW's have an aluminum oil pan that is hanging down in harms way, I have replaced a few for cracks from hitting things
Jan 16, 2008 at 7:43 AM
BRITTANYORTON
[quote:3c2ae83ce3="2CarPro Jack"]Usually if it leaks that much overnight the problem is low on the engine like a drain plug or possible pan gasket. Some VW's have an aluminum oil pan that is hanging down in harms way, I have replaced a few for cracks from hitting things[/quote:3c2ae83ce3]
Thank you so much for your information it was very helpful, and extremely fast! Again thank you!!!
Jan 16, 2008 at 12:19 PM
2CARPRO JACK
  • 11,533 POSTS
my pleasure
Jan 16, 2008 at 2:50 PM
