CLUTCH STUCK TO FLOOR THEN NOT ABLE TO PUT INTO ANY GEAR.............PROBLEM???????? NEW CLUTCH OR WHAT ELSE
Jul 29, 2009 at 9:29 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
This will normally be a hydraulic problem, check the fluid. if low check for a leak at the slave Cly at the gear box and the master cylinder, look under the dash where the push rod comes through, if one or both are leaking they must be replaced and the system bleed of air.
