Recently, I started my car up, having used it the night before, and found that I could not shift out of 1st gear. The clutch engaged properly and I was able to drive, but I physically could not move the shifter out of the 1st gear position. I left it engaged in first gear with the e-brake on on a slight incline. Previously, I have noticed minor problems such as brief difficulty switching into certain gears (only 5 and reverse i believe). Additionally, this problem occurred once before when the car became stuck in neutral for about 10 seconds.
Thank you for any help you can provide.
-Alex
-Alex
Nov 17, 2008 at 1:00 AM
