[quote:53e192ea3b="wdevaney"]2000 Volkswagen Passat
where are the rain drain plugs[/quote:53e192ea3b]
When you open the sunroof, there is a hole on each corner that you can only see if you look from the top. Those holes are the drains. If the holes get clogged you car would get water inside when it rains. The plugs for the drain on the front are close to the door hinges when you open the door. On the rear the plugs are under you rear bumper.
Apr 23, 2010 at 3:40 AM
