2000 Volkswagen Passat
2000 VOLKSWAGEN PASSAT
108,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAMESH
I have a 1.8 turbo passat. Quite often, I need to add few bottles of oil in between 5000 mile oil change. There is no oil leak. Does this car requires extra oil?
Jan 7, 2008 at 1:41 PM
GUSTAV
  • 4 POSTS
Please somebody knowledgeable reply as I have the same problem, but I do have a noticeable oil leak on the slab. Thank you.
Feb 25, 2012 at 9:31 PM
EXOVCDS
  • 1,883 POSTS
What engine (size/type) is in your car?
Feb 25, 2012 at 9:58 PM
GUSTAV
  • 4 POSTS
My passat is a 2000 model, 1.8 Turbo, 4-cyl. The engine is an ATW. Thank you.
Feb 26, 2012 at 7:08 AM
EXOVCDS
  • 1,883 POSTS
Common oil leak areas are:
- valve cover gasket & chain tensioner gasket
- oil cooler seal
- oil pressure switch
- camshaft or crankshaft seals
You will need to do a visual inspection to see where the oil is coming from. Repair shops use a dye that they put in the oil so that fresh leaks can be found via UV Light.
The first in my list is the most common... the PCV system needs to also be checked for correct operation, or the new gasket kits will fail early.
It shouldn't take a shop long to find a leak and they usually don't charge for the inspection if you end up getting the work done by them.
If you end up doing the repair yourself, they might charge you for the inspection.
Feb 26, 2012 at 7:25 AM
EXOVCDS
  • 1,883 POSTS
Forgot to mention cracked oil pan... also common, but since you didn't mention
hitting anything, the oil pan is probably OK.
Feb 26, 2012 at 6:36 PM
GUSTAV
  • 4 POSTS
Looks like my work is cuto out for me. I really appreciate the input and I think I will take the suggestion above to have a shop detect the leak and go from there. Thank you very much!
Feb 29, 2012 at 12:54 AM
