I am getting no voltage at the small black/red wire at the starter (terminal 50) when the key is turned ( I saw ~8 volts once out of 30 key turns - all the way off, then all the way on). Is there a fuse and/or relay in the circuit or might I have a bad ignition switch? Also, is the clutch switch in the starter circuit on a 1995 Passat? I have also heard that the security system could cause the car not to start?
Sep 6, 2009 at 1:22 PM
