VW Polo 1.3, Model 1995, 115.000 miles
1995 VOLKSWAGEN
GEORGIO
My car does fails to start because tha fuel pump does not work. I tested the fuel pump with external 12Volts and works fine. I measured the voltage at the plug that goes to the fuel pump and i found 11,6 volts for only 1 sec when i turn the key to on.
I also replaced the fuse with no result. I also bypased the relay with i wire but again without result.
what do you think is the problem? What should i do next?
Jan 13, 2007 at 11:41 AM
BRUCE HUNT
  • 3,754 POSTS
Are you saying that with the external 12volts the pump will work and under the normal circuitry it fails?
Jan 13, 2007 at 5:43 PM
