VW fuel injectors
VOLKSWAGEN
hi, i have a 2001 vw passat and recently my timing belt broke, and i changed 2 intake valves. after that it ran fine. recently though it started to have a rough idle. i checked my compression and it was fine. so i went through my injectors...disconected the cable on each one while it was runnig to see the efect. on the rear 3 the idle got worse but the first one didnt change. does this mean my injector is bad
Oct 19, 2006 at 10:28 AM
CAPTAINMANIACDRIVER
  • 15 POSTS
Why not believe that one injector is at least slightly clogged and fix it. Chemicals and an aircompressor with saftey visor
Oct 30, 2006 at 4:13 PM
