Low Rev at Idle and other little problems.
VOLKSWAGEN
PHILLYBOY
Car Specs:
Gold III GL 4 door '93. 117000 Km on it.
It's been about a week that when the engine is cold (Im in Canada at -10 temperatures) I heat the car up for about 10-15 minutes before leaving for work.
I noticed that when I stop at a stop sign, the engine almost stalls. If I turn on the heating the engine goes down to a very low rev then gradually comes back up to par. If I turn on the Back window Defrost it does the same thing.
Since This morning, I noticed that when I stop, the same problems occur but the Oil light blinks and then stops. Even when the engine is hot it still does the same thing now. I am not quite sure what the problem is...
I was thinking that it might be the Alternator (Original part), Or Perhaps the Battery, but I rather ask experts. All the belts where changed on the Car, I got my Oil changed 5000 Km ago.
Any help would be appriciated.
Jan 18, 2006 at 6:20 AM
2CARPRO JACK
  • 11,533 POSTS
could be the battery
Feb 10, 2006 at 4:49 PM
NIXINIX
I am having the same problem with my polo, I had an engine diagnostic run and apparently it is the idle air control valve that needs changing
Mar 10, 2006 at 11:40 AM
