jetta GLlll
VOLKSWAGEN
STUART4
My jetta was running a little rough, sputtering and stopping when Idle. I replaced the plugs, wires and roter. seems to run a lot better now, however when I start to accelerate it cuts out, after giving it more peddle it takes off then after it shifts its starts to cut out again until I give it more peddel. I'm not sue what else I can do.
May 9, 2007 at 11:43 AM
BIZSKILLS119
If you have not checked the idle cable. you can adjust the nut at the end of the cable so that the car idles at higher rpm's.
May 21, 2007 at 11:08 PM
