jetta 1996
1996 VOLKSWAGEN
ROSE2008
Hi have a 1996 Jetta ,
Going over a bridge my jetta got really hard to turn
then the temp lite went on and got really harder to turn .
when I stopped the car , smoke came from the drivers side and green fluid was on the ground
Is this a radiator leak or a power steering fluid leak ?
Nov 18, 2007 at 7:46 PM
P1S7OL
  • 45 POSTS
Considering that VW's use an orange-pinkish coolant it doesnt sound like a coolant leak. More than likely your power steering pump failed. Or your water pump failed. thats also a common problem. If your water pump failed, and you continued to drive it, you may have caused more damage to your engine. But it sounds like a PS pump to me. hope it helps!
https://www.2carpros.com/forum/automotive_pictures/119074_Jettainhouston_1.jpg
Nov 19, 2007 at 6:09 AM
