IM DYING IN THIS HEAT!
VOLKSWAGEN
SWISS.SKIN
i have a 1997 VW Golf Trek edition and the air conditioner stopped working last summer, i didnt have the money and summer was almost over so i didnt deal with it. finally i took my car in and on shop told me that it was the ac shut off relay and i went to another shop where they re tested it and told me that the relay was getting power and the problem was electrical, i have taken the car in 3 times now and there is still no answer on what the problem could be, please help i am dying in this summer heat
Jul 17, 2007 at 1:22 PM
CHRONICSILVER
  • 11 POSTS
I'm not sure on the actual symptoms of your problem. Is the A/C blowing hot air? Is it not working at all when you turn the HVAC controls (the knobs inside the car)?
Jul 17, 2007 at 11:49 PM
SWISS.SKIN
the light for the controll comes on however the a/c dosnt turn on i had it checked to se f it needed to be recharged and it was right on
Jul 18, 2007 at 9:46 AM
CHRONICSILVER
  • 11 POSTS
The fuse for the HVAC is probably blown, unless it's something worse. The wiring for the HVAC could aslo come loose. Since the pressure if good that means that there is an electrical problem, rather than mechanical. I'd try to check the wiring and the fuses. If none of those are the causes, I would replace the relay, no matter what they told you.
Jul 18, 2007 at 3:28 PM
THEQUEENANDME
We have a 97 VW Jetta that did the same thing. We replaced the high pressure switch and everything started working fine. It cost us $97.00 at the VW dealership and we replaced it ourselves. It just screws on and off. Check for a checkoff valve before replacing and be careful because it is under high pressure.
Jul 27, 2007 at 11:53 AM
