Idle rpm at 3000 always. wont retard to normal 7-800rpm
2012 VOLKSWAGEN
BARTABADILLA
I have 1992 VW cabriolet convertible. 1.8L 4 cylinder,
mileage is 107,000+/-. i have replaced all vaccum hoses connected to the plenum just incase there is a vaccum leak, i have cleaned the maf sensor filament with a carb cleaner. all necessary tuneups have been made, i have alot of experience with engines but this is my first EFI engine. i have applied every troubleshooting proceedure i know from my non-EFI experiences, but i cant seem to make the Idle rpm go down to normal rpm.
Everytime i start the ignition, the engine starts normally but the RPM rises to 3000rpm and stays there.. What more can i do to try and bring down the IDLE RPM to 7-800RPM?
Jul 27, 2007 at 2:17 PM
69TONYD
check your idle stabilizer valve ,these are bid problems with1.8 eng,and adjust idle air bypass screw on intake manifold.good luck
Nov 10, 2007 at 9:18 PM
