Check engine light is flashing
VOLKSWAGEN
RHERNANDEZ7
VW Passat 2003 1.8T code reader reports random misfires on cyclinders 3, & 4 Replaced all spark plugs
what could be the problem besides the coil packs
Dec 21, 2006 at 1:05 PM
2CARPRO JACK
  • 11,533 POSTS
Since the cylinders are next to each other , I would look for a common thing between them. Vacuum leak, would be a good place to start. Does the engine have good compression on all the cylinders?. Could be a blown head gasket between 2 cylinders.Look for anything those two cylinders share.
Dec 21, 2006 at 3:07 PM
SERVICE WRITER
  • 9,123 POSTS
The flashing of the light means damage is being done to the converter, setting that aside...
To help isolate misfire problems, swap parts in question from the cylinders misfiring with the ones that aren't. When the codes shows movement to the other cylinder, you have your bad part.
This isn't always posssible such as a bad head gasket, but can eliminate, plugs, wires, fuel injectors anyways.
Dec 24, 2006 at 10:35 PM
