I have a 2001 Jetta 2.0 about 89,000 miles. This car has had numerous problems since i got it. With in 2 weeks one of the fans went out, then the oil cooler broke. after 4 flushes of the coolant system about a month apart, i still have traces of oil in my coolant. Most recently, i had about 1/4 tank of gas, stopped at a Chevron to fill up. As soon as i got back in the car, the check engine light was on. I have ran the code at home, and it comes up p0171, saying "bank 1 too lean" I have been running fuel injector cleaner in with each full tank the last 2 weeks or so. ( i believe it is lucas's brand not sure of the spelling) that hasn't helped. I pulled out both O2 sensors, neither looked really bad. I have also cleaned out the throttle body, the air filter, and MAF sensor. I have pulled apart other little things but made no progress. I have turned off the light a few times. It will stay off for a few hours (driving, starting and stopping the car) then go back on. Any other options i can try other then pull out the fuel injectors and have them cleaned? Thanks.
Also. When i start the car, the coolant light always comes on. Stays on until the car warms up, then goes off. When inspecting the overflow tank, i found small clumps of oil on the prongs on the inside of the tank where the plug is. Could that be the problem?
Mar 26, 2007 at 8:34 PM
