Anti-theft system won't turn off after replacing car window
VOLKSWAGEN
VIOLETJ
The driver's side window on our 1999 VW Passat 4 door sedan (62,000 miles) was shattered by a rock from a passing car. After the auto glass technician replaced the window, the car won't start. When we turn the key, the dashboard indicator lights, fans, radio, etc. come on, but nothing else happens. The battery is fully charged. The indicator light near the door lock that tells us the anti-theft system is engaged continues to flash and will not turn off, either with the key or the remote control. The locks and windows work, but the dome lights do not. We think the anti-theft system was somehow affected by the work on the window. Is this possible? Is there a way to disable or reset it? The auto glass technicians don't seem to have any ideas.
Jun 2, 2006 at 4:35 PM
LOSONE
  • 1,616 POSTS
There is an alrm switch on the door lock. Turn the key first to the right and then back too the left, it should reset.
If not take off the door panel a reconnect the door alarm switch it probably came off during the window replace ment. Good luck
Jun 2, 2006 at 5:37 PM
