Several things may be wrong here, but it doesnt sound like anything to major. When was the last time the oil was changed/filter was installed? Whoever installed the filter may have overtightened your filter, damaging the seal. Alternately, the gasket from the old oil filter may have stuck to the engine where the filter mounts instead of coming off with the filter, allowing oil to leak through the openings created by the filter gasket not making contact with the engine. The only way to know for sure is to take the filter off, and if you are going to do that, you might as well change your oil again. Remove the filter like normal when you change your oil. Prior to installing the new filter, clean the area that the filter mounts to the engine. You may see part of the old gasket/seal stuck to the motor, you may not. If anything is remaining there, remove it. Make sure that the area where the filter mounts is free of any debris or leftover oil, and then lubricate the new filters gasket/seal with clean engine oil, and screw in the filter with your hands! Do not use a filter removal wrench! You dont want the filter to loose, but you dont want it very tight either. Just right in between. hope this helps!
Nov 24, 2007 at 7:37 PM
